Amp Body on Boost?
I think I can answer my own question here. Looks like the Amp/Circuit has a longer wheelbase than the Boost. 11.6 vs. 11.2, respectively. So that's a negative. I'd need to swap in the Circuit chassis to make it work. Might be worth it, as I really like the look of the Amp DB's body and wing. At least I can use the Amp wing either way. :)
You are correct. I tried going the other way: putting an extra Boost body on my AMP MT. The Boost body is too short. Additionally, the chassis of the AMP is a little wider and shaped a little differently than the Boost's chassis.
