Broken link mount bolt
Shinook
My Temper gen 2 fell off the couch and the tiny M2 bolt holding the link to the axle broke in half. Rather than replace it with the same weak bolt, I was wondering if anyone else had any suggestions for what they did to replace it with something stronger?
If it was the bolt it self that broke, the only way to replace it with something stronger would be jumping up in size to 3mm
which would include drilling out the metal ball links to the larger size which might not as easy as it sounds .you would have to keep the ball links smooth and do not mar them or the movement would be effected. Usually the plastic mount brakes before the
bolt does might have been just a bad bolt
