brushless motor 1/8 to 5mm
Joshnewb
what all would i need to do to convert my ruckus from a brushless motor with a 1/8 shaft to a 5mm shaft?
just get a 5mm pinion to match new motor? would that domino into replacing other gears?
any other steps would be involved?
just got this thing few months ago, needs more powah
To clarify, the motor you will be buying will have a 5mm shaft? Yes, simply purchase a 5mm pinion, as long as you keep the pitch the same you will not have to replace the spur. Unless it needs new gearing because of the motor you buy.
yeah, current system has 1/8in shaft, motor i'm looking at is 5mm shaft
would the ruckus even have room for this? or would there be much modding involved?
[QUOTE = "Joshnewb, post: 9441, member: 758"] que ferais-je pour convertir mon ruckus d'un moteur brushless avec un arbre de 1/8 à un arbre de 5mm?
juste obtenir un pignon de 5mm pour correspondre à nouveau moteur? ce domino remplacerait-il les autres engrenages?
d'autres étapes seraient impliquées?
juste eu cette chose il y a quelques mois, a besoin de plus de powah [/ QUOTE]
Salut moi j'ai acheté un moteur en 3660 g gool rc et j'ai commandé un pignon en 48 dp (taille des dents ) avec un diamètre de 5 mm pour l'axe moteur !
