Put xmaxx tires on a ruckus
That....would be an amusing sight! If you try it remember to post up some pictures.
I have 1/8 MT tires on my Ruckus with the help of some HotRacing adapters.
Looks cool. Chews up plastic driveshafts and tranny gears like it was designed to. I’ve since swapped in HotRacing driveshafts and will be ordering metal tranny gears. Remember to set the slipper slightly loose.
It is also ver top heavy and tippy now, even with all the suspension clips out. I probably need new shock oil, but that will only do so much good.
