Aiden
- Location
- NSW, Australia
Hi all,
I've been after some new wheels for the ECX Boost. I really like the stock wheels and they look great with the spoiler off, you get that sprintcar kind of look. But after seeing the Bandit VXL setup posted over at that other ECX forum, I was inspired to try a 5-spoke upgrade for my Boost. There wasn't anything wrong with my stock ones, but, you know how it is. Too many hours spent listening to the Fast and the Furious soundtrack in my formative years I guess.
Here's how I did it all for five bucks (Australian) and a little bit of superglue.
I ordered these wheels and the matching 'rear' set from eBay. They showed up and the front rim was too wide (it rubbed the knuckle). So I thought, doesn't matter if I wreck them. I cut off the outer bit of the wheel so that it only had the 3 ribs – 2 on the outboard side and 1 on the inboard. Tried re-fitting the tires after I sanded the front wheels flush (I had cut the excess off with a hacksaw) and they fit great. No superglue on the front, they're plenty tight. And anyway, they're just for pointing the Boost in the right(-ish) direction.
Same deal for the back wheels, you just (carefully) prize the existing tire off the stock rim and fit it onto the aftermarket rim, and then you superglue it in place. I coloured the lip of the rim in with a silver sharpie before I fit the tyres back on.
The existing wheel hexes are a real tight fit. When I did a test fit it took a hammer to get them back out of the wheels. At least they didn't snap! At the moment to get the wheels on and off I place the pin horizontally, line up the wheel with the stuck-in nut and fit it that way. Annoying, but it's doable if you're not too unco.
You might not see it in the photos but the axles actually stick out a couple mil. Easy fix, the standard wheel hexes are about 5.5mm deep, I've ordered some 7mm clamp-on ones and that should take up a lot of that excess axle and give me a stance pretty close to original. All up I will have spend AUD $5 on the wheels and AUD $4.88 on the 7mm nuts. Pretty cheap and cheerful mod with not much of a headache, I'd say. You'd be laughing for about USD $7.
