Yea, you'll have to experiment with different weights. I prefer 30wt. Associated makes great shock oil.
I thought one of my shocks on my Amp MT was underfilled because its damping was way less than the shock on the other side. That was not the case though. I didn't even know there was such a thing as "better shock oil". It's just viscous drab in a sealed container?
I'll try draining it tonight though, maybe it gets better if I replace all of the original shock oil. But I'm thinking it's just a dud valve. It gives a squirty feeling, as if there are bubbles in it (but there are not).
I see. I should empty it completely then. It had a bit of dead (undamped) travel at full extension as well. I figured any bubbles would float up if I moved the plunger thing up and down, but then again this ain't water I guess.
