Steering Spindle
regme
Hi
I was after a fix for this, both the screw and spacer have come out of the steering spindle and are lost, is there a way of fixing this?
I can't find the spacer as a seperate part all I can find is this ECX214005 which is the complete set.
However it seems that changing them to aluminium might be the way to go, but then I would also have to replace the Hubs as well.
Was looking for a cheaper option.
Cheers
Unfortunately it looks like you'll still need to source a compatible screw if you buy the aluminum steering/spindle carriers. Loosenuts has a good workaround.
