Hello guys, my almost 4 years old son and I have 2 amp mt at the moment.
We started with some accessories because 9 hours for batteries charge wasn't an option...
After having tons of fun with them and bashing them very hard, what should happen, happened...
Broken parts :
For this one I took the part on the other and I will order spare parts from ecx.
I wondered why the steering was shaky...
This one is more problematic and will lead to probable brushless upgrade since the engine is really making a bad noise and won't probably live long...
So, at the moment, we have one amp up and running and the other waiting to be fixed.
The plan is to upgrade the (currently) dead one while waiting for the other to need same medicine...
First things first, I need to order a Dsft Set Long Compl HD(ECX232000) to repair the broken one.
The bearing and suspension are still ok for the moment so I chose to go into sexier upgrades.
I was thinking about was steering servo to start with.
If I choose any mentioned in the recommended upgrade thread (Power HD 1501MG, MG996R, or Hitec HS5645MG, would I need anything else to make it function properly ?
What would be more useful, installing a servo saver or the servo saver eliminator mentionned in the forum or going without any for the moment ?
Next, I saw on the forum that using the 13003 receiver I could go brushless without changing the Tx, could anyone confirm ? Which bl motor you would advise for going along with ?
Do you have any advice's regarding tires, to get more grip ?
Last question, which tool do I need to open and close connections between the motor and the Rx as seen in this picture :
Thanks a lot for reading,and most importantly for your help, I will post progression here as we learn our way !
Broken parts :
