Wanting to upgrade shocks
Briguy
Virginia Beach
Ok. Got the truck running and it is insane. I am thankfull for all the help and suggestions. It ran so well i ran it into a car tire and broke the front shock.:( . Now i wanna upgrade. I also have to replace the front tower. I cant find what size the shock is. I see different mm. What is mine? Where do you find info?
Thanks :D
The ECX shock sizes are a bit annoying, because it's hard to find exact same length replacements for other brands. I think the fronts are 90mm hole-to-hole, and the rears 105. But this is from memory and it's been a long time since I measured them, so you might want to verify that information.
If you get longer ones, you lose some suspension travel because they won't compress as short. If you get shorter ones, you lose some travel cause they don't extend so far... But a few millimeters is no big deal.
