Why dd the pinion fall off?!?
He noted that in his write up. The motor shaft was too short to properly attach the pinion he was using.
Cool! 1--What track is it & where? 2--I thought you said the 175RC pinion solved the problem = did you use it? Why dd the pinion fall off?!?
Thx
I've heard multiple times that my truck is sitting too high. Still using stock shocks with 35 weight oil and the collars removed in the front and added 35 grams of lead on the front end.
