Could I get some better pics of the spacer you’re talking about?? I have a 6500kv spektrum on 3s and I’m getting bigger tires so I already know the rear driveshafts are bound to blowSlash steel driveshafts
I use these, they have lasted a while for me, no issues yet, on 3s 3200kv with low ish gearing. They bolt right up, but need different wheel hexes and also a spacer behind the hex on the bearing side of the hex to reduce play, but that's cause I'm using somewhat narrow wheel hexes from a redcat gen8 i had lying around.
Hello sorry for such a late response heres all the images: i gave the measurements also. These calipers arent the mosr accurate, maybe I'm just bad at using them but as long as its close, it should be fine. I kinda did some changes recently like different links and stuff so that might look different. Also you probably want narrower rear hexes as mine are too wide and i have a narrower wheel nut on there to compensate.Could I get some better pics of the spacer you’re talking about?? I have a 6500kv spektrum on 3s and I’m getting bigger tires so I already know the rear driveshafts are bound to blow
Much appreciated, I’m ordering the same ones and I’m sure my hobby shop in town has the spacers that’ll work.Hello sorry for such a late response heres all the images: i gave the measurements also. These calipers arent the mosr accurate, maybe I'm just bad at using them but as long as its close, it should be fine. I kinda did some changes recently like different links and stuff so that might look different. Also you probably want narrower rear hexes as mine are too wide and i have a narrower wheel nut on there to compensate.
They're just washers so if they dont have em just go to your local hardware store lolMuch appreciated, I’m ordering the same ones and I’m sure my hobby shop in town has the spacers that’ll work.
Where can I find those axles?Slash steel driveshafts
