Cool! What makes it the "most advanced?"
Ya, me too = Midnight & D3 Dirtinator!I'm old skool I'm use to the green machine
Did you find reviews that said the card and system works well? Holds up? I still have 15 yr old Trinity motors that are working!!
Update on SkyRC brushless systemCool--thanks for being the guinea piglet!! Please keep us posted!!
What do you mean "motors run with stock ESC?"
I heard from Horizon support that you can use the 13003 receiver if you want to change out the ESC, so you don't actually need to upgrade the radio. The radio is tiny, but otherwise very good in my experience. It has dual rate for the throttle, which is awesome if you have a kid and want to quickly dial back the power before you hand over the remote. I know my son digs it.
The 13003 receiver is $16 though, sadly. It would be nice if it were a $5 part like the Flysky RX.
What part of the set up was tricky? Also what else didn't come in the box that is needed for the set up?Update on SkyRC brushless system
It is incredibly fast. Using 3s Lipos. Program card works wonders. Being able to have a built in LiPo cut off is a great feature. Save from buying more gear. Being able to set punch and motor timing is a bonus as well. ( dont set both to Max on first run) my mistake. Wasn't expecting it to go so fast from the word go. Over all. I would rate it 8/10 set up is a little tricky
I have used a Traxxas receiver in my amp MT. I was using a spectrum receiver. It fit very wellHi
Has anyone found or used a waterproof recover box in their ECX amp. I am looking at the traxaas one but I am not sure I'd it will fit
cheers
There is no good reason to go with ceramic bearings unless you're doing some serious racing. The advantages only apply to racers when compared to the extra cost of them.Fast Eddys Bearings, is it worth paying for the Ceramic over Std?
Also are the Std ones worth it over stock?
T-Bone bumpers.....do we use Circuit ST 2wd ones?
Cheers
And even if you race, don’t bother with ceramic unless you’re in a grit free environment like carpet or asphalt. I race exclusively on dirt and just use sealed cheap bearings. Fast Eddies, Boca, TBR ect. I just order 10 packs of the most common ones that fail like rear hubs and diff output shafts. Typically replace them with every diff rebuild.There is no good reason to go with ceramic bearings unless you're doing some serious racing. The advantages only apply to racers when compared to the extra cost of them.
Go with the standard FastEddyBearings as they will be a huge improvement over stock bearings while still being very affordable.
