Temper gen2 with the mods.
A member of KCRC in Kansas City..doing modifications , helping create a comp. class to fill the void of the Losi predecessor of yesteryear ........Tires 4.45 BoomRacing Hustlers mtx on steel bead locks.....Lipo battery, with 2 different connector options.... New "DinkyRC" servo battery mounting plate, and steering link, tucked out of the way under that plate.......Its getting there..........
I think the lugs down the center of the stock tires are to big and close together....
The drive shaft stiffener....super glue it in...IMG_20190819_184012.jpg.
I got .078 wire to fit into these drive shafts
Nice rig, what is that like an 800mah pack? My buddy just put a losi carbon battery plate on his gen 2 and is looking for batteries. Battery on axle works great, Ive been running that way for a couple years. Here is my gen 1. I use smaller 500mah packs
looks like you got doomsday upper and lower links? That is a nice rig by the way
What's the length on those shocks is there any way I can talk you into taking a picture without the body on exactly where you mounted the shocks because I have a gen 1 and a Gen 2 and sometime in the future plan to get the Gen 1 back on the Road cuz I robbed some parts for my Gen 2 but I'd already upgraded Gen 1 with the wider axles. have you guys had any problems with spinning the axle shafts inside of the stock plastic bowler spool?
-Correct I am running gen 2 barrage axles/links and a barrage transmission/driveshafts with a Losi 1/18 motor. I've been meaning to bend the lower links, but it still works good.
-Sure I can snap a picture later. I drilled the holes where I mounted them. I'll post a link for them too, they Yeah Racing brand.
-Yes I blew out a rear spool, I just went to the Redcat Racing metal spools.
Portable crawler course piece's chainsaw carved rock....
Relocated the electronics, mounted loosely to the upper links...then cut and reversed the tray they were mounted in....IMG_20190902_173656.jpg
I made up these using some 1/8 plastic....
After all the mods so far...the video begins with it on a 50° degree angle..... The plywood beyond that is on a 45° .....all part of the textured crawler course I built....
