Honeybadger
Note: this_feature_currently_requires_accessing_site_using_safari
Anyone know of an upgrade option for EXC 1/10 2wd chassis, skid plate, bulkhead...
I've upgraded everything around it but now it's given up the ghost.
Thank you
Thank you, appreciate the tipH-R makes an aluminum front bulkhead. No chassis or skid plate
Yours broke because you have aluminum arms. It made the bulkhead take all the force. Put RPM arms on it.
I haven't dealt with them yet. Everything on mine that's now aluminum is because I broke the OEM parts...Maybe I'm wrong but every time I break something replace it with aluminum
I *HATE* Hot Racing parts and their customer service, but no one else makes a lower bulkead/LCA mount that I know of. I replaced the stock one because I broke it, the pins were stronger than the bulkhead and tore it up on a front end crash. Now, if I crash, it destroys the plastic RPM arms which are about $20 to replace the set and take ten minutes. Usually they don't even break, they flex and flex back. I did break the front of the chassis neck one time with this aluminum bulkhead, but other people have reported doing that with the stock one too.
I've broken 2 chassis since 2015 both were in the winter when it was cold outside, first time was a water shut off valve that stuck 3 inches out of the ground in the emtpy lot next door and the other was a nose dive into concrete.
Aluminum a arms are best suited for shelf queens unless the car was designed with aluminum a arms in mind which none of the Ecx vehicles were.
