Did you get these. I been looking and the dimension look like it will fit but it sure if the shaft size is same for the gear connectionAwesome! I'll get some measurements, and probably grab some.
The hot racing ones do extend but I haven’t ordered them. Waiting on others to see how it went before I pull that trigger for 25.00 or whatever.Do those shafts extend? They look solid. Not sure that would work in the temper.
The shafts (the part that sticks out of the axle and tranny) are the same size as Axial and all the other ones (5mm I believe)
So most driveshafts should fit.
I'd look at the short metal ones on Ebay.
Let us know how they fit please I would like to replace my drive shaftI ordered these last week. I think they will work but don't know for sure. I think they are a little long but I can always cut them if they are. The stock ones don't exactly bind but I found them kind of rough that's why I want to try a CV shaft.
https://m.ebay.ca/itm/2PCS-1-10-RC-...-Shaft-88-115mm-For-AXIAL-SCX10-/182720731492
For sure but it may take a while to arrive since it's coming from China.Let us know how they fit please I would like to replace my drive shaft
Sure- on my build with the shocks fully compressed, the drive shaft is at its shortest, about 86mm. With my shocks (HR internal springs) fully extended, the drive shaft is only lengthened by about 4mm- up to 90 mm.
how did the driveshafts work?I ordered these last week. I think they will work but don't know for sure. I think they are a little long but I can always cut them if they are. The stock ones don't exactly bind but I found them kind of rough that's why I want to try a CV shaft.
They haven't arrivedhow did the driveshafts work?
Hopefully the eBay ones will work. It's hard to tell from the photo. I will keep you guys posted once I get it but I have no idea how much longer it will take. The tracking said it left China like 2 weeks ago but it was updated and said it left China again today....the shafts from rc4wd were too large in diameter. so they wont really work well
