Amp DB or MT rear suspension mount
hzrdus
Does anybody know if there is a aluminum replacement part available for the ECX1092 rear suspension mount? It is the piece that holds the hinge pins for the rear swing arms. That is a very cheesy piece and the way the pins go into the little block is so weak.
Thanks in advance.
I have not ever seen this part available as an aftermarket part. Sorry I couldn't offer more help. Are you breaking this part?
There's a tread on here, 2 I think, that discuss this. I'm not up to par with computers, so I don't know how to add a link here for them. One title starts with ecx1092. It's like 9 threads down on the amp forum. There is no replacement as you've found out, but you can use longer hinge pins, and drill out the front hole of the mounting plate, I've done it and had no issue since. There's more detail in the previously mentioned thread
