That's a good idea, and I am using stock gearing, but in steel. For now.Maybe if you put snow skis on the front? Doubt it’s possible with 2WD otherwise.
What pinion and spur gear?
Yeah. That makes sense. Thanks!I bet its possible. A dirtbike can, which is much heavier with similar or even slightly less rubber contact. Just have to go fast enough and stay on the throttle.
