Ethan-playsrc
I have a brushless motor for my ruckus 1/10 2wd and i need a 5mm bar pinion and a spur gear does anyone have any part numbers or recomendation
Best is too just Google the size you need and see where its sold. I would look at an all steel set.I have a brushless motor for my ruckus 1/10 2wd and i need a 5mm bar pinion and a spur gear does anyone have any part numbers or recomendation
I beg to differ on an all steel set. If you have your gear mesh set correctly, you won't have any problems. If not, you'll strip the spur gear which is the easiest and least expensive part to replace in the drivetrain.Best is too just Google the size you need and see where its sold. I would look at an all steel set.
3 s lipo on a castle brushless system and 8th scale tires had proven that to be un true for me. I've broken literally every component and replaced them multiple times. I even had to install larger hubs and bearings in the rear to deal with the extra stress.I beg to differ on an all steel set. If you have your gear mesh set correctly, you won't have any problems. If not, you'll strip the spur gear which is the easiest and least expensive part to replace in the drivetrain.
Stock ECX spur is 87. I'm running a 18 and 19 tooth pinion depending on how warm it is outside. Robinson Racing hardened steel pinions are great and inexpensive. Like Jddemelfi said, google it. Add 5mm to narrow the search.
3 s lipo on a castle brushless system and 8th scale rice and cane style tires had proven that to be un true for me. I've broken literally every component and replaced them multiple times. I even had to install larger hubs and bearings in the rear to deal with the extra stress. I can't run any pinion over 19. Unless its winter time. My RC is very impractical.... but man its fun.
You vastly overpowered and over geared it plus put far too large and heavy a wheel and tire. Plus your slipper must not be set properly. There is a big difference between brushless and 8th scale power (and weight). My Amp MT runs 3S brushless with just the metal gear set and I have broken nothing.3 s lipo on a castle brushless system and 8th scale tires had proven that to be un true for me. I've broken literally every component and replaced them multiple times. I even had to install larger hubs and bearings in the rear to deal with the extra stress.
Exactly what I was going for. And it all works now..... have AVC and I run my slipper set correctly bieve it or not.... It was built to be ridiculous... And it is. . The suspension is all custom. Thing is an absolute beast. Only regret is not using a 4wd platform.You vastly overpowered and over geared it plus put far too large and heavy a wheel and tire.
It’s what you were going for but you are using your extreme example to disagree with what is likely the best advice for OP, to keep the stock plastic spur gear and not go to steel. I think it’s the best advice despite your extreme edge case where steel might be required.Exactly what I was going for. And it all works now..... have AVC and I run my slipper set correctly bieve it or not.... It was built to be ridiculous... And it is. . The suspension is all custom. Thing is an absolute beast. Only regret is not using a 4wd platform.
