New record!
P0SEID0N2025
So its been a while since ive been on here and recently i have gotten my ecx amp up to 56mph (barely tapping full throttle)!! Its too fast for its own good. ? My current setup is Flysky gt5 radio, onyx brushless 70amp esc, and the motor is a fuze 3300kv brushless motor! The battery is a zeee 60c 5200mah. Stock spur gear and slippers, and a 28t pinion. I somehow ended up with this thing from a basher, to a speed run car ? i do need to replace the shock towers from flipping over 2 times though, luckily i have spares!!
PoseiDon, this is my Amp and it's been clocked at 65 mph. It's been totally upgraded to the max.
Wow, you blew out the tires! Man that's a first that I've heard that happening. Yeah, it's amazing what you can do to these vehicles. If you could put wings, flaps and a tail I believe you would have a flying vehicle. Not to far fetched as they do have such a thing.
I also got another new record ? since i got this record ive got a 81t spur gear to make it even faster! Also i blew out the tires ?
Get some speed run tires. better drop that thing down and adjust your toe and camber for speed running. I replaced the stock plastic camber and steering links with steel Traxxas turnbuckles. They work great.
