ThanksMore weight in rear than front, which is common on the 2wd chassis. As well as not enough preload on the rear shocks/ too much preload on the front shocks. You will have some trial and error. To fix this, try some combination of adding spring spacer clips to the rear and taking some off from the front. It also may be necessary to change the springs for stiffer/ softer springs.
