1/10 4wd
Is everything on the truck still stock? Basically have you done any upgrades? If not, you'll have to replace all the plastic links with adjustable metal ones. I'm not sure on the exact ones for the 4wd Ruckus.
These will work on the 2wd version of the Ruckus
https://www.amainhobbies.com/traxxas-aluminum-turnbuckle-camber-link-set-blue-4-tra3741a/p17601
I don't own a 4wd so not sure if they are an exact bolt on fit. Again, they'll work on the 2wd version. Given the positioning of the motor and trans on the 4wd, I think all 4 need to be the same size. That kit has 2 that are shorter. But that should give you a place to start looking.
Basically what I did for my fronts and rears for camber was, I measured the plastic link already there. Then went to the store and just found some metal links that were about the length I needed, but got them slightly shorter, to make room for adjustments (and also the ends for the links).
