1/10 Ruckus 4WD Parts Diagram
95PGTTech
rural NJ
A manual and a parts diagram seem to be unobtanium (went so far as to contact Horizon Hobby), tripped across one in the far corners of the internet
Welp, I stand corrected, I probably should have clicked the link first.
Shame on you Horizon Hobbies..............
Yeah those are dead links. I have my ruckus 2wd manual and the parts diagram is easy to find online, but I’ve been thinking about a 4wd swap using factory parts. I know the body is the same so how different could they be? There are a few other old dead threads wondering the same thing and guys with 4wd models who needed to order replacement parts. I did a lot of searching and couldn’t find a manual.
I tripped across it today when I accidentally googled 4wd control arms instead of 2wd. It’s not the whole manual but it’s the important parts diagram. Other searching had told me they are basically two entirely different trucks with almost zero parts overlap, the picture confirms it. I actually have a used 4wd on the way so I may do a side by side series of pictures
I found the one for the Circuit https://vortexhobbies.com/parts_finder_workspace.php?vt=Car&brand=699&vehicle=334&expl=1600
The Torment 4x4 is also on there but the 4x4 Ruckus listed is the 1/18 not the 1/10 :confused:
Here is a link to the entire manual for the ECX Ruckus 1/10 4x4 https://www.manualslib.com/manual/769446/Ecx-Ruckus-Ecx03013.html
This one is better as it has a parts list and parts diagram in it https://www.manualslib.com/manual/1434269/Ecx-Ruckus-Ecx03242.html#product-Ruckus ECX03242
BTW if you need a manual for something manualslib most likely has it.
