2wd ruckus shocks
Joshnewb
what are you all running for shocks on your ruckus?
still running stock on mine, but if or should i say when i break one, or when i just wanna upgrade, i'm looking for suggestions
the ecx upgrades look decent, so do the hot racing ones, but i'm skeptical on the Hot Racing brand, i see a lot of people running the traxxas "big bores" as well
I would not get Traxxas big bores, I would get something threaded so you do not have to mess with those pre load clips. The Ecx ones are supposed to be pretty good.
I would go with ECX aluminum shocks they are light and last a long time make sure the are for the ruckus though.
Mine leak a little but that's because I do big jumps and run thick oil and makes it squeeze out.
Try running around 27 weight in the front and about 35 in the back for good handling on the track and bashing. Play around with it and you will find what you want. It always depends, what do you want your vehicle to do...start from there.
