2WD Torment ESC's
WithinU
Land of Oz
Hi Gang,
Just curious if the stock ESC that comes with a 2WD brushed Torment can handle a brushless motor?
From what I can tell, it will handle a 2-3S Lipo, so I am assuming it can handle a brushless motor with those packs?
The brushed version is running a DYNS2210 ESC, and the brushless version is running the DYN4940?
Is there a certain Kv rating to stay within if I try staying with the stock ESC's?
I appreciate all your help.
No the stock brushed esc is only for brushed motors. Brushed motors have two leads positive negative. Brushless have three motor leads can't use just two.
The DYN4940 is only a 45a esc be fine on 2s with a 4300kv motor but if you want to run 3s no more than a 3300kv motor IMO.
Ahhhh…... yes, I knew that too. Ok, thank you. @Heyitsme
