Aluminum Rear hubs and ECX ball studs?
Discussion in 'Suspension' started by Joshnewb, Sep 9, 2017.
Tags:
  1. Joshnewb
    Joshnewb Well-Known Member
    88
    4
    May 16, 2017
    I have rpm rear hubs on my 1/10 ruckus. Also have team associated adjustable steering and camber links with ECX ball studs.
    I've been having problems with the top mounting hole for camber links on the rpm hubs
    --the ECX ball studs slowly strip out, like the holes are a hair too large
    thinking of getting the aluminum rear hubs
    Will the ECX ball studs screw into the top holes?
    or would i be forced to use included screws and return to stock plastic camber link?
  2. rendnb
    rendnb Well-Known Member
    85
    17
    Aug 27, 2017
    If you get the ECX aluminum rear hubs, the ECX ball studs will fit. Were those RPM hubs the oversized ones? If so, then you might have to swap back to the stock bearings.
  3. i_r_beej
    i_r_beej Well-Known Member Supporting Member
    660
    206
    Feb 9, 2016
    I had the same issue. I even tried using CA glue ("superglue") on the threads per RPM's suggestion. Didn't work and the ballstuds would work their way loose very quickly. I just used a small 4-40 nut with a drop of blue thread lock to secure the ballstud. No problems any more!
    rendnb likes this.
  4. rendnb
    85
    17
    Aug 27, 2017
    Gotta love thread locker. Great idea on this one, I might have to give this a shot!
  5. Joshnewb
    88
    4
    May 16, 2017
    i actually had some longer hpi ballstuds laying around so i used those with 3m lock nuts
    ECX ballstuds are just too short
    and yes.... blue threadlock
    i_r_beej and rendnb like this.
Share This Page
