Fdnavy
i just up graded my sons amp mt with a kinexis 4000kv brushless with included esc, metal gears, flysky GT-3C radio with included receiver, and a 5000mah 2s lipo. Car is now fast as f***. There are a few things I am not sure about. 1. The throttle trigger is reversed. When I pull back the car goes in reverse I connected the colored coded motor wires to their corresponding colors on the esc. I can fix this using the reversing channel 2 on the controller. Is this normal? 2. Crazy sloppy in reverse. Wheels wobble like something is broken. I have read that I can install hot racing bell crank kit, but it’s very hard to do and I can’t seem to find any directions. 3. LIPO is new to me I programmmed the esc to cut off at 3.4 it was factory set at 3. Is this sufficient? The next available setting is 3.7. 4. With the cutoff set does that mean the car will stop working automatically? I don’t want my son to run the battery down too far and damage the battery. 5. 1c charging for this battery is acceptable? 1c= 5amps correct? 6. Is there a way to slow down initial acceleration so it doesn’t pop a wheely? I have the controller set to 70% dual rate and it still pops the front end up. I am also looking for tire recommendations that are plug and play. Something good on pavement and dirt? Should I replace the steering servo? If so what’s a decent replacement? Lastly why else should I upgrade. Thanks in advance
