AMP MT Spur
Jez
Hi,
My AMP MT has a stripped spur but I can’t find a replacement (ECX 1076 I assume) in the UK.
I would prefer a metal one if possible? Is there a part from another model that would work?
I could remove the slipper clutch if needed? This is for a brushless conversion.
Thanks in advance…
Hi mate!
I think all ECX 2WD share transmission, so this may be handy. Report results, hope it helps.
Hi,
Thanks in advance…
Your stock one does fit all ecx 1/10 scale 2wd models. Its 87 teeth and 48 pitch
Hot Racing is the only company I know of that makes a metal spur for it. SECT877 is what you’re looking for. They also make 85, 83, and 81T configurations for gearing choices. You re-use your stock slipper with this, just buy new pads. I recommend glueing them to the spur, roughing up the metal pads with coarse sand paper, and eliminating the nylon lock nut and going to a double nut with loc-tite. A good start point I use is tighten until the spring completely binds then loosen 1/4 turn.
