Amp wheels
Tamyosho
Since I wasted some money following what I read in another thread here's some info on Amp wheels:
Duratrax and Louise ST 2.8 wheels: smaller diameter (100mm / 4.0"), you need the wheels with 1/2" offset to get the same width as the stock tires.
If you want the same diameter more or less, you'll lose about 1/2" in width total using SCT tires. You need "Slash (2WD) front" ones or ProLine Rear split 6 ref 2721 which for some reason have more offset.
