Axles for the ECX Temper?
CumminsFan
Does anybody know if theres any axles you can use on the temper? Are the barrage axles (gen 2) the same as the temper? Can you use the everest 10 axles? TIA
I have the Barrage CVD axles on my temper. Not sure that it was totally worth it...
I had to enlarge the openings on my HR Alu C Hubs to fit the joint through.
At full steering extension, the housing of the CV joint rubs against the inner bearing of the Alu HR steering spindles. There is also a good bit of steering chatter when the wheels are turned past about 60-75% of their range. I know this can be an issue with CVD, esp at full speed. But at my backyard rock pile, I almost never run at full throttle, so I am probably just going to let it go for now.
Finally, I do believe that there has been an incremental increase in low speed response, traction, and smoothness.
Hope this helps!
