Battery dimensions
RoyRoy
Rochester MN
I’ve seen some photos online where certain LiPo batteries are too fat to fit under the standard plastic “T” holder. Do I need to worry about this with a 2s? Are there any brands that don’t fit?
Thanks!
Roy, no problem with a 2S battery. However, with a 3S you will need to raise the T holder, as you call it. If you just have a battery bed, then you will have to change the way you tie down the battery, with 3S. I myself use battery straps. Here's how I raised my platform on my Amp Crush, to accommodate a 3S LiPo. Hope this helps you out.
