Brushless motors exc1/18
F123
Went on my nerv that dirt came into the Engine and lasted not long.
Cracy Pony B2430 7200k with 35A ESC
Fits plug and Play only modul 0,5 steel Engine gear is needed for 2mm shaft. I used 13 teeth. Runs because of blown up weels around 60 kmh. Full trottle without crash to the back is possible over around 20 kmh. Is a verry good combi if no jumps diff lasts relatively good. With jumps lasts only if you catch around right speed otherwhise lasts not realy. I have to exchange it after around 8-13
2400mah lipo charges.
At the moment i don't see the combi anymore but i guess something semilar exists in the size.
Replacing of the Receiver and Remote control needed. Makes sense to buy one which is able to asjust power if you have Kids.
Greetings
well I don't know to much about them but I know that you could get some engine grease or bring it to your local hobby shop. And with the diff I would purchase a aluminum and do you know anyhing about amp mts and what I can do with mine
