I am trying to do this for my daughters AMP but have found the gear cover won’t fit due to the shaft of the motor being too long. Is there a gear cover that will fit?When I finally smoked the stock motor, I put a Traxxas Titan 12 turn motor in the truck and it gave it a considerable jump in torque and speed on 2s lipo. It's not going to be as fast as a brushless system, but it definitely gave it more speed
I think you can just drill a hole (diameter of the shaft) in to the coverI am trying to do this for my daughters AMP but have found the gear cover won’t fit due to the shaft of the motor being too long. Is there a gear cover that will fit?
This is exactly what I didI think you can just drill a hole (diameter of the shaft) in to the cover
Just wondering, came across your post here. I recently also replaced the stock motor in my son's AMP with a Titan 12T 550 motor. It only ran for a short while before the ESC burned up. I not only upgraded the motor, but also went to a 8.4V 7-cell battery. I'm wondering if you stayed with the 7.2V 6-cell battery setup. Did I make a mistake by increasing battery at the same time I changed to the 12T 550 motor?This is exactly what I did
