Custom ECX Micro Temper Crawler Build
Distress
Chassis is made from delrin. Links are done using the instructions for Lynx Micro Tech McRC links (btw, you can also use those chassis for the ECX micro Temper) and geometry is changed to eliminate side to side movement/ improve articulation (you can place your stock links in a position like this to see a huge improvement as well).
Driveshafts are extended using a Bic pen.
No springs.
Wheels are Redcat Sumo Micro Crawler and tires are RC4WD SS.
