sixstringhook
Picked up a new clear body from horizon for my ruckus. it says its the direct replacement, but when i go to fit it, the holes are all off. My ruckus is pretty old, from probably around 2012 or so and I have been rebuilding it. When I chatted with customer service at horizon, they said that the older models MAY have used different body post sizes, but couldn't tell me for certain.
Anyone with a newer ruckus able to measure the distance between the body mount holes, where the body posts mount to? I need to see if I need to order new body mounts in addition to the new body posts.
These are the body posts horizon's customer service said I need - https://www.horizonhobby.com/front-rear-body-post-set:-1-10-2wd-ruckus--torment-ecx2010
These are the body mounts that the body posts fit into, but im not sure what I have for body mounts will fit those posts (if that makes sense) https://www.horizonhobby.com/front-rear-body-mount-set:-1-10-2wd-ruckus--torment-ecx2009
so those holes that the body posts mount in to the body mounts are what I need measured.
