Do ALL 32p gears work together correctly?
Machztechplus
ontario
I've been having massive issues with 48p gears so I decided (with some help from you guys) that I am going to switch to 32p pinion and spur gears. I was looking at the Robinson racing 26 tooth 32p pinion with 5 mm bore but the spur gears they sell have a massive bore... I was wondering if other companies' gears will work... It may have been part of my problem before... I was using an aluminum Hot Racing spur (48p) with a pinion(48p) that came with my Fuze 3800kv a while back...
Any input is appreciated.
I've been using team associated 58 56 and 54 tooth spurs(bored to fit)and axial 32p 13 tooth pinion on my 2400;) in the back of my torment (2wd) with the steel gears upgrade and aside from literally blowing up my transmissions every now and then the truck performance is crazy fast!! I also found that you can easily get an integy wheelie wheel for a slash to fit and keep the front end down. I also have my slipper tightened up.
