Do you lube metal transmission gears?
MADitto
I installed the ECX metal transmission gear set yesterday. I did not lube the gears, as the stock ones looked dry. Should I have added some?
I'd like to add that you should NOT use a heavy, sticky grease like you might use in a car or motorcycle. The lithium grease suggestion is a good one. FinishLine is another good brand and they make some good, light, PTFE greases that work well for bearings, gears, etc.
