Dynamite Passport P2 Charger Help
masavy
Hello,
I had bought this charger to use with Lipo batteries but ended up getting 5100mah NiMh batteries instead. If anyone uses this charge can you please clarify the different charging modes when selecting NiMh and which to select? The options are Charge, Auto Charge, Discharge, Re-Peak and Cycle. I used the stock 1800 batteries my AMP came with yesterday and set it to NiMh, 1.8a, 6 cell, CHARGE.
I did notice the first time it charged it stopped at 1450mah and chimmed that it was done but the second time it actually went over 1800 and I stopped it at 1900, so I'm guessing I should set the cut off timer using the app for 1800 and then for 5100 when using the larger batteries. What I'm wondering is what the different charge settings are and when to use each. Thanks
