ECX Barrage 1/24 Torque fix.
BIGWORM
Here is a pretty easy way to give your ECX Barrage 1/24 some SERIOUS torque! You will need two things! 40 dollar investment for a whole new level of torque!
You will need...
The RC4WD R5 1/18th transmission (it comes with a motor).
https://www.amainhobbies.com/rc4wd-r...SABEgKW3_D_BwE
And the mounts for the transmission to the frame.
https://www.shapeways.com/product/GN...li=marketplace
The only thing you will need to do is drill the drive shaft mounting holes circular. The hole in the drive shafts comes in the shape of a D. I simply stuck a drill bit in the hole and made the circle round. See the video below for more detail.
Heres a video (not mine) of it done to a clone of the ECX barrage. 1/2 way through he will show how it drives. He also shows the drive shaft D shape he drills out.
Instead of plowing or powering over things. NOW it will crawl over EVERYTHING!
This is COMPLETELY worth the 40 bucks spent.
You will need...
Awesome! I was going to try a different trans but wasn’t sure which one to go for. This is a great mod!
