Ecx barrage more cost
The doomsday is being discontinued. I bought one for parts for the barrage gen 2.
Did you use your front and rear axles from the Doomsday? I've got the temper and upgraded to the garage axles and had to buy a Doomsday truck to use for axle replacement cuz I keep breaking the original garage axles mostly from over tightening the nut and tumbling down the rocks just for the record I hate those X headed spacer extensions because a weak point for the set pin hole is which causes more leverage on the axle shafts
