ECX Ruckus, 1/18 scale - rear transmission double D striped
mirage550
All, recently bought an 1/18 Ruckus. On day 3, the right rear wheel was not spinning. After a full break down, found that one of the gears in the rear transmission had a double-d slot which had stripped out and was causing the screw to back off under any torque conditions. This effectively, causes the wheel to not have any power.
Does any one know of a metal replacement for this part? The drive shaft is metal and the gear in plastic (which is why this is stripping). Anyone else had this problem? Any solution other than buying a new rear transmission?
