Ecx ruckus 2rwd driving problem
Denideni
My ruckus 2rwd won’t drive proparly.
When I begin to drive I goes well, but if I want to drive backwarts it takes a while before it starts driving backwarts.
After a while the car suddenly stops en don’t drive for a minute of so, the steering works. Just no driving.
Someone an idea what is could be?
Check your low voltage cut off if you accidentally turned it on and you are running NiMH they have high internal resistance compared to lithium batteries and will trigger the LVC under loads. My cars don’t go into reverse while in LVC mode because it cuts throttle to 50%and I need to hit 100% brake to switch into reverse so not quite there.
What esc do you have pics always help.
It's an Absima AB10 I think. If you don't have the manual look for it online. Maybe the brake settings or LVC, or radio settings are causing strange behaviour when driving backwards.
