Esc wont for forward or reverse
1. Welcome to the madness ;)
2. A little more info will help peeps estimate your problem. Like, dose it power up OK? I know this sounds simple but, are your batts fully charged? Have you checked all your connections? Hard crash? Just trying to help. (y)
Esc? & Vehicle pls...
Bound properly...
Could b a number of things
Plugged into wrong channel maybe?
Jdeon, here are some things that could be causing your problem; a bad esc, esc not binded to controller, trans or differential jammed, receiver not wired too the right channel or you have a burnt motor. I would disconnect your motor and connect it directly too the battery and see if it spins, that way you can eliminate the motor. That leaves you with the esc, receiver, binding, a bad controller and jammed differential. What type of setup do you have? And what vehicle do you have?
