How to set the SLIPPER CLUTCH?
BriaN
I recently installed 60A esc and a brushless motor, so I had to redo my slipper clutch, then I realized, I still don’t know how to set the slipper clutch, and I was confused on what the “turn the clutch one and one quarter turn loose” meant. So.. how should I set the slipper clutch on the ECX amp for a brushless system? A video would be extra helpful! (The ones on YouTube are for 4WD!) thank you
I use that little 4 way wrench that comes with new R/C's. You turn the nut on the slipper till it gets tight and you can't turn it no more then turn the nut 1 1/4 turn loose. Count the turn by using your 4 way wrench one full rotation of the wrench then a quarter turn more.
