How do you adjust the shocks so that the rear wheels lay more flat on the ground instead of only the edge of each rear wheel is making contact?
I used the middle hole in the top and the upper hole on the bottom as shown in the picture.View attachment 1396
Double checked and they are in the holes shown in the diagram. I did notice there are two "spacers" on each shock. Could that be the issue?
I'm running the Traxxas camber links. I would recommend longer screws for the rear.I assume you are looking for camber adjustment? If so, you'll need to find a set of adjustable upper suspension arms. Unfortunately, I haven't looked into it yet so I'm not sure what to recommend for you. It doesn't look like ECX makes any.
No problem. Imagine how it's going with my wife after buying 2 Amps and a Torment and a new charger and 3 more batteries and,and,and.......
