LiPo Battery Question
The C rating indicates the maximum continuous discharge. Take the C rating and multiply it by the capacity.
So for your linked battery it would be: 20C x 5000mAH = 100A maximum continuous discharge.
I would personally look for a little higher C rating. 35C or greater.
FWIW I've got two 20C Venom LiPos. (2S, 4000mAh, 20C) and found them to be sufficient, even when running a 17.5 brushless motor in my Boost in "stock" buggy racing. However, when I started running a 100C "shorty" pack, I did notice a little more "punch."
However, if you move to a more demanding brushless power system (3500kv or higher) you would likely benefit from a higher "C" rating as those motors will place a higher draw on the battery.
Bottom line, you really aren't going to suffer from buying a battery with a higher "C" rating... that just means that you'll have room to grow.
Buy the best you can afford, or you'll wind up buying twice. ;)
By the way you might want to avoid cheap "2S2P" packs. They have very nice C ratings for little money, but the common problem of mismatched cells is much worse on a pack with parallel cells.
The C means discharge rate, if you have a 5000mAh LiPo battery,the 20C discharge rate is : 5Ax20C=100A, 50C is : 5Ax50=250A
You're a little late to the party on this one. ;) I already posted that further up. haha
