Looking for battery upgrade for ECX Ruckus
If you go up in power and longer run times you also go up in heat and could risk burning up your motor. If your motor is running hot you might have to gear down (smaller pinion).
Do you have a nimh or a lipo? 7.2v is a nimh, 7.4v is a lipo two different kinds of batteries if its a lipo you need a lipo charger and set the jumper on the esc to lipo.
Thanks for the info guys, ended up getting an 8.4v-3300mah nimh battery
