My Ruckus makes a clicking/grinding sound every time I try to turn. What should I do?
Servo gears are probably stripped. Does it do this all the time or when the steering reaches max travel left and right?
Most likely a servo on its way out - stockers are plastic geared and will only stand up to a couple decent crashes before you loose a tooth. Another cause, if it’s a 4x4 and doing this under power, could be wear in the front axles.
