My trucks gears are giving a clicking sound when it is pushed forward...
Hey so I took off the gear cover after last bash to just inspect things and now my gears are sounding like a standard transmission getting mashed, you know, grinding.
My gut says this is wrong. But I don't know how to fix it....
Check to see if one of the bolts holding your motor in place haven't loosened and caused the motor to move slightly out of mesh.
My cars do that to its completely normal. Sometimes your gear mesh can become too loose while driving you will hear high pitch noises of the gear teeth colliding at high speeds. or shredding gears. It’s in the design of these gears they will make a lot of noises while rotating. However if you push the car slowly and it sounds like clicking it’s from the rotor passing by the stator inside the motor (a brushless motor specifically) and what happens is the gears spin the motor and when it gets to a certain point the motors magnets are within attraction of another part of the stator and the motor “bounces” the gears around and it sounds like clicking.
