Need tire advice
Dodgers304
Bought this a month ago and have done some simple upgrades cant just go down to the local hobby shop and get parts . I have to see what all you guys are doing then hope I order the right thing of Ebay so I've got pro line tires in back and stock tires in front
Sidewinder 1410 series esc 3800kv motor stock 87t spur gear traxxas 25t pinion gear on 3s and aluminium shocks weighted down the front end today to get a speed run in but just couldn't quite get to Full Throttle it was all over zipped tied the servo saver to remove some play it helped a little I'm looking for different tires should they be the same all around anyhepl on what tire setup would work for speed runs and bashing
Nice looking rig there Dodger. From the looks of the first pic you could lower the body mounts a hole or two to not allow wind to get up under body. Just a suggestion. (y)
