Power idea
Stephen1806
I have an srx 200 reciever with a broken antenna whole brunch of lights and a 500mah drone battery
Would anything bad happen if i use the reciver as the power hub for the lights?Notes_190106_040334_aa1_1001_1546765427129.jpg
The reciever in car is sr415
And i do not intend to connect the two.
Sr415 for steering and throttle
Srx200 powerhub only. 3.7v NiCd 500mah
I don’t see why not. I mean if it works on the bench it should work in the rig. Even if it did pick up a compatible signal, what’s the worst thing that could happen? I’m not even sure it would cause the lights to turn off. I could be sooo wrong but I don’t think you’d have anything to lose.
